version backup to default backup directory
    May 26, 2006#1
    I've been trying to configure the version backup feature to save files in my default backup directory without any success. Only the bak file is written.
    Anyone tried this?
      Jun 14, 2006#2
      I can partially get it to work.
      1) If I set
      Backup Files on Save:
      Append .BAK to existing extension = selected
      Default Backup Directory = <directory selected>
      Version Backup:
      OnSave = checked
      Format = $b\\$n$e
      then I get a backup appearing (with the specified format, not with a .BAK extension) in the backup directory when I save.
      NOTE: You need doubled backslashes in the "Format" field.
      2) If I set
      Version Backup:
      OnSave = checked
      Format = $b\\$n.$c$e
      Maximum Number of Backups = 5
      then I get mutliple backups appearing (with the specified format, not with a .BAK extension) in the backup directory every time I save. But it seems to ignore the "Maximum Number of Backups" field. Anybody know how to get this to work?
