Double clicking on a word that contains a non alphanumeric character
5
    Sep 05, 2006#1
    When I click on a word or expression that contains a period UltraEdit selects only part of the word. For example, if I click on the "aaa" portion of "aaa.bbb" then only "aaa" is selected.
    The behavior when the word contains an underscore is different: if I click on the "aaa" portion of "aaa_bbb" then "aaa_bbb" is selected.
    Is there a way to configure UltraEdit to select the whole word in the first case? That is, by clicking on "aaa" I would like to see UltraEdit select the whole of "aaa.bbb"
    Thanks for any suggestion.
    6,672577
      Sep 05, 2006#2
      That's nothing mysterious. It's a Windows standard. Microsoft Word for example uses the same word selecting method. A point is punctuation mark and so will never be a word character.
      For more details and how you can select complete "aaa.bbb" with a double click see in help of UltraEdit/UEStudio the topic with the not surprising title Double Click Selections.
      If you don't know where the help is: menu Help - menu item Index - tab Index - enter dou and press Enter or Return key or short F1 - dou - enter.
        Oct 16, 2006#3
        This is a very nice feature, and I have a question about it:
        Is it possible to use a "linebreak" character as a delimiter?
        I just need this: when I select a line by double clicking it while holding Ctrl key -- I wish the line was selected without the linebreak. So if, for instance, i delete the selection -- the empty line remains.
        So, if it's possible, guys, let me know how to use "linebreak" as a delimiter.
        6,672577
          Oct 16, 2006#4
          borilio wrote:Is it possible to use a "linebreak" character as a delimiter?
          The line break characters are delimiters for Ctrl+double click. Are you sure that you do not triple click for selecting a line because triple click selects a whole line including the line termination. A triple click is the same as using Edit - Select Line.
          As far as I know there is no method to select a whole line without its termination with the mouse. Following auto-loaded macro assigned to a hot key could do that:
          Key HOME
          IfColNumGt 1
          Key HOME
          Key END
            Oct 19, 2006#5
            Mofi wrote:The line break characters are delimiters for Ctrl+double click.
            Yes, indeed!
            "I must have been doing something wrong" :)
            Thanks for response, Mofi!
            You're nice guy.
