Hi, I have a question about UltraEdit's forced interval file change detection. I have a local file which is modified frequently by several remote computers. Under the File Change Detection heading in the configuration menu, I have set automatic updating of changed files and a forced poll interval of one second. Then I turned on File Change Polling for the file in question. It works well, but my question is whether the one second interval is too low. I know the file is only reloaded in the editor if a change is detected, but how is that detection done? I'm assuming it is left up to the operating/file system to mark the file as changed, rather than UltraEdit constantly reloading the file to check. Does anyone know if the file is only read from disk if there was a change detected? I just want to make sure the file isn't read from disk over and over again every second.
Thanks in advance.
Thanks in advance.
