Hope you don't mind a suggestion for UltraFinder.
I've found myself changing the "Find where" directories back and forth quite a bit. So I'm wishing you had "save" feature so I can get my old directory locations back. Better might be to just be able to enable/disable the directory locations with a check box maybe next to the next to the delete button for the file locations?
Hope this make sense.
Anyway
Love your products. Keep up the great work
Phil
Anyway
Phil
