How to work around error on uninstalling UltraFinder?
PostNov 27, 2016#1
I'm unable to uninstall UltraFinder. See attached screenshot.
I checked the file paths and the files, they are all there. Any suggestions?
Error message upon uninstall.
PostNov 28, 2016#2
It looks like the command to uninstall is recorded wrong in your Windows registry as the required double quotes are not correct set.
I suggest to run from Windows Run item on Windows start menu or from within a command prompt window:
"C:\Program Files\IDM Computer Solutions\UltraFinder\uninstall.exe" "/U:C:\Program Files\IDM Computer Solutions\UltraFinder\Uninstall\uninstall.xml"
That should uninstall UltraFinder completely.
PostNov 28, 2016#3
Thanks Mofi, that worked perfectly.
