How to find a phrase in file contents while omitting specific phrases?
PostMar 26, 2019#1
What I want to find in the file content: 'eat at joe'
But I additionally want these results omitted: 'eat at joes diner because it'
So my results would only contain text such as: 'eat at joe street cafe on the...'
Basically how do I add a NOT qualifier (or equivalent) to my UltraFinder file contents search?
6,826625
PostMar 26, 2019#2
This can be done with a Perl regular expression search using negative lookaheads and lookbehinds.
For the examples the regular expression search string is eat at joe(?!s diner because it) using a negative lookahead.
PostMar 26, 2019#3
That works great! Thanks, Mofi.
I am accustomed to another software that has multi-field boolean, I had never used or attempted Perl before.
Addition for that solution for anyone else that finds this post:
If I was looking to find the phrase: eat at joe
But I wanted to omit: eat at joe"
Meaning that I didn't want to see entries where the word joe was immediately followed by a double quote.
The search string I used was: eat at joe(?!")
It caused many false positives in .zip files and graphical image files.
So I added this to the 'ignore files/types:' field: *.zip;*.gif;*.png;*.jpg;*.swf;*.ico;*.eot;*.woff;*.ttf;*.icc;*.psd;*.woff2;*.svg;*.svg2;*.;*.svgz;
To get a clean result list, omitting the false positives from zip and image files.
You'll want to review the omitted file types yourself in lieu of a quick copy/paste.
Hope this helps the next person.
