Searching across multiple lines
    Aug 17, 2004#1
    I have downloaded UltraEdit, and I am assessing it for possible use. I was wondering whether it is possible to search across line breaks, i.e. a block of code.
    Sincerely,
    Joe
    38
      Aug 18, 2004#2
      The quick answer is "yes". You can either select the code you want to match, if that's your intent, and then call up the Find dialog via a CTRL-F for example, and then do a Find Next, or you could insert the appropriate line breaks in your search text using a ^p, or equivalent. Read the Help on the Find dialog for more details on this and other capabilities.
      Dan
      Daniel Kirkdorffer
      http://www.kirkdorffer.com/
      61
        Aug 20, 2004#3
        Is there a way to search accross an unknown set of lines? So for instance I have:
        public void test() {
        And I could match from the first { to the closing }. I think other programs use a multi-line mode for this.
        Any thoughts?
        38
          Aug 20, 2004#4
          Refer to documentation regarding the use of regular expressions. You should be able to do what you want to do.
          Dan
          Daniel Kirkdorffer
          61
            Aug 20, 2004#5
            Yes you are right. I was in fact doing it wrong.
            This appears to work:
            {.*\p*}
            Thanks!!
            5
              Aug 30, 2004#6
              Hi Guys,
              this doesn't seem to work for me. I want to search across multiple lines, but it is not known how many lines there are. 2 or more parts need to be found before the replace-function shoud match. So I'm looking for something like ...
              find:
              KEY1[?^p^b^r^n]++KEY2
              or better, because i have to replace something in KEY2:
              find:
              ^(KEY1[?^p^b^r^n]++^)KEY2
              replace:
              ^1KEY3
              nothing seems to work as soon as I try to go multiline.Tryed both syntax variants:
              KEY1[.\p]*KEY2
              No difference.
              please help.
              Beejai
              206
                Aug 30, 2004#7
                Maybe you can get an idea here that will help:
                General thread: How do I replace multiple lines
                Software For Metalworking
                61
                  Aug 30, 2004#8
                  Yeah my previous solution only worked in one case. It should be simple to select code fragements like this:
                  function blah (
                        int a=1;
                        a++;
                  If I want to select the function body from ( to ) I do not appear to be able to when the number of lines between the brackets is unknow.
                  I tried: (.*\p*) and \(.*\p*\)
                  Is there a solution anyone is aware of? Other Regex solutions appear to be able to handle this via a flag. I really do not thing a macro should be the answer.
                  Thanks!
                  5
                    Aug 30, 2004#9
                    mrainey56 wrote:Maybe you can get an idea here that will help:
                    Sorry, but no, that didn't help. I have to do a s&r on a folder structure containing thousands of files.
                    The problem can be tracked down to one thing: Is there a way to specify a unknown number of Lines in UE's regExp-ability ? As soon a working solution for
                    [?^p]++
                    is found, all probs in this thread would be solved.
                    If it can't be done, it should realy be added to the todo-list on UE v10.20d / 10.30
                    please help
                    Beejai
                      Oct 24, 2004#10
                      Hum, this seems to work for me.
                      I have a multine text :
                      string1
                      any
                      number
                      of
                      lines
                      string2
                      With UE set on unix regexp, doing a 'replace in files' with :
                      Find :
                      (string1)(.*\p*)(string2)
                      Replace with : \1 \3
                      Regexp : on
                      will output :
                      string1
                      string2
                      Thierry B.
                      5
                        Oct 28, 2004#11
                        Hey, above would be ace. But I can't reproduce that.
                        I got 100 testfiles, one contains:
                        <head><meta name="Schluessel" content="PK-V0000-T4444-D0000-N0000-G310805-A0000-X0000-B00000002">
                        <meta http-equiv="Pragma" content="no-cache">
                        <meta http-equiv="expires" content="1800">
                        <meta name="Date" content="01.09.2001">
                        <title>pin8</title>
                        </head>
                        Find: (N0000)(.*\p*)(pin8)
                        Replace: \1 \3
                        RegExps set to unix style
                        Output: Replaced 0 occourences in 0 files.
                        ?? :cry:
                        plz help.
                        Beejai
                          Nov 04, 2004#12
                          Ok, I understand why. This is because in my case, pattern (string1) and pattern (string2) are the exact content of a full line, not a part of line as in your case.
                          TB
                          Edit: This is a potential bug in UE because I tested your case in Visual Regexp 3.0 and it works (http://laurent.riesterer.free.fr/regexp/). See picture :
                          5
                            Nov 05, 2004#13
                            thierrybo wrote:Ok, I understand why. This is because in my case, pattern (string1) and pattern (string2) are the exact content of a full line, not a part of line as in your case.
                            I agree. I tried to explicit define the strings as part of a line with
                            (.*string1)(.*\p*)(string2.*) or (.*string1.*)(.*\p*)(.*string2.*)
                            but it didn't work either.
                            Then I realized there must be something wrong with the ".*STRING" pattern in general. Try this:
                            Testfile:
                            <head><meta name="Schluessel">
                            Replace ".*sel" with "****" results in:
                            <head><meta name="Sc****>
                            <head><meta name="Sc**** content="PK-V0000-T4444-D0000-N0000-G310805-A0000-X0000-B00000002">
                            which is terribly wrong !!
                            But a replace ".*Schluessel" with "****" gives the expected result:
                            It might have something to do with the double quotes. But they should be a normal member of the "."-set.
                            Please can any developer take care of this issue?
                            best regards...
                            Beejai
                              Jul 11, 2005#14
                              I know this is a dead thread, but I thought I'd post the solution in case anyone else out there is looking.
                              They had an error in their RegExp.
                              (.*\p*) looks for multiple occurrences of any character, followed by multiple occurrences of newline.
                              What you want is (.*\p)* which looks for multiple occurences of (multiple occurences of any character followed by a newline) ie: multiple lines.
                              Cheers
                              Tom | d3
                              http://www.tomauger.com
                              5
                                Jul 11, 2005#15
                                Not as dead as you may think ;)
                                Thanks for the info, but it's still not possible to search across multiple lines with your pattern. If I gave up to quick, can you supply an example ?
                                Beejai
                                Read more posts (4 remaining)
