Reverse Show Lines and get all lines displayed again
    Feb 19, 2014#1
    I found some text in my file, then I used "Show Lines" to show only the lines that contained the found text.
    Now, how do I quickly reverse the effect of "Show Lines" and get back to viewing the entire text file? I mean, without just re-loading the file.
    10210
    10210
      Feb 19, 2014#2
      Press Ctrl and the * (multiply) key on the numeric keypad together to expand the listing again.
      Cheers...
      Frank
      6,672580
        Feb 20, 2014#3
        In other words click in submenu Hide/Show Lines of menu View on menu item Expand All. The command can be added to a toolbar if often needed and using the mouse is preferred. The hotkey of the command ViewExpandAll can be also changed in the Key Mapping dialog at Advanced - Configuration if a keyboard without numeric keypad is used like on some laptops/notebooks.
