Sort a list of IP's
Sort a list of IP's
    Jun 17, 2005#1
    How can I sort a list of IP's with UltraEdit ?
    I can sort a list of IP's in Unix by
    sort -n -t . +0 -1 +1 -2 +2 -3 +3 -4 <file>
    UE can sort the list but it puts them in
    nuermical order.. such as...
    191.116.33.195
    191.17.3.241
    191.17.71.242
    191.222.0.106 which should be..
    191.17.3.241
    191.17.71.242
    191.116.33.195
    I have the 4 keys but they are not in columns but seperated
    by .
    191.222.0.106
      Jun 18, 2005#2
      Quick and dirty macro, surely not the best solution. The macro expands all values to 3 numbers by adding the missing leading zeros, sort it and removes the leadings zeros. Remove the red lines at the end of the macro, if you don't want to remove the added zeros. The file should contain only the IP addresses and every IP address should beginn at start of a line. The regexps are in UltraEdit style!
      Bottom
      IfColNum 1
      TrimTrailingSpaces
      Find RegExp "%^([0-9]^)."
      Replace All "00^1."
      Find RegExp "%^([0-9][0-9]^)."
      Replace All "0^1."
      Find RegExp ".^([0-9]^)."
      Replace All ".00^1."
      Find RegExp ".^([0-9][0-9]^)."
      Replace All ".0^1."
      Find RegExp ".^([0-9]^)$"
      Replace All ".00^1"
      Find RegExp ".^([0-9][0-9]^)$"
      Replace All ".0^1"
      SortAsc IgnoreCase RemoveDup 1 -1 0 0 0 0 0 0
      Find RegExp "0^([0-9][0-9]^)"
      Replace All "^1"
      Find RegExp "0^([0-9]^)"
      Replace All "^1"
        Jun 21, 2005#3
        Mofi wrote:Quick and dirty macro, surely not the best solution. The macro expands all values to 3 numbers by adding the missing leading zeros, sort it and removes the leadings zeros. Remove the red lines at the end of the macro, if you don't want to remove the added zeros. The file should contain only the IP addresses and every IP address should beginn at start of a line. The regexps are in UltraEdit style!
        Doesn't seem to work.
        Do I need to select the lines beginning with an IP ?
        I get an error..
        "Search string not found!"
        It seems to fail at line 7..
        UE needs a MACRO debugger or at the very least a way to step thru
        the macro one line at a time...
          Jun 21, 2005#4
          The macro is written for a file which only contains IP addresses at beginning of the line. So copy the addresses temporarily to a new file. No need to save the new file. And you have to check the macro option Continue if a Find with Replace not found at the macro properties.
          For "debugging" simply insert the ExitMacro command, where the macro should stop so you can look the result of the macro execution til this point. Use "Revert to Saved" from File menu to undo all changes, edit the macro to move the ExitMacro to a new position or delete it and run macro again.
          Sometimes it is even better to insert following commands, where you want to pause the execution of the macro:
          GetString "Break 1"
          Key BACKSPACE
          Now the macro shows a dialog, where the user can enter a string, which is inserted into the file. When the dialog is opened, look at your file, then enter a single character (1 space for example) and press OK. The inserted single character is immediately deleted with backspace and the macro continues until next GetString command. "Break 1" is a text, which is displayed above the enter field, so you can define different "break points".
          This "pause" method can be expanded with following commands:
          GetString "Break 1"
          Key LEFT ARROW
          IfCharIs "1"
          Key DEL
          ExitMacro
          Key DEL
          This gives you the possibilitiy to stop macro execution, when you enter only the character '1' as string in the GetString dialog, all other entered single characters continue macro execution.
            Jun 25, 2005#5
            It seems I need to run the macro more than once to get
            the file sorted.
            I created an excel spreadsheet to generate a list of random ip's
            A1 =INT(RAND()*(255-1)+1)
            B1 =INT(RAND()*(255-0)+0)
            C1 =INT(RAND()*(255-0)+0)
            D1 =INT(RAND()*(255-0)+0)
            E1 =A1&"."&B1&"."&C1&"."&D1
            I take the E column and dump it into UE.
            152.54.108.100
            183.75.176.103
            231.106.225.241
            59.62.210.126
            131.26.17.43
            81.163.117.222
            73.87.217.1
            176.223.122.213
            17.242.89.182
            210.15.137.2
            30.231.95.178
            39.108.69.5
            31.156.150.84
            44.121.62.178
            88.188.227.92
            119.77.60.42
            240.239.80.72
            233.133.173.100
            134.207.176.17
            41.232.141.5
            195.13.175.36
            114.54.47.196
            184.149.13.176
            75.130.247.174
            83.57.161.132
            131.8.48.42
            248.17.96.45
            55.157.228.87
            131.64.201.243
            169.11.95.1
            23.224.121.158
            111.35.136.121
            191.92.83.197
            4.65.23.198
            224.183.84.54
            203.35.30.138
            After sorting 23.35.30.138 will appear after
            195.13.175.36 instead of 17.242.89.182
            Sorting it 1 more time, and its sorted :)
              Jun 25, 2005#6
              Although 23.35.30.138 is not at your list, I have found the problem. I guess 23.35.30.138 was the last IP address and this last line was not terminated with a valid line ending (CRLF for DOS or LF for Unix).
              I have added the green marked macro code, which adds a line termination on last line of the file, if it is not already present. Then the sort works with only one run.
              Note: If you normally work with Unix regular expressions, add UnixReOn as last command to the macro code or this macro will also turn off your prefered setting of Unix style Regular Expressions at Advanced - Configuration - Find.
