From time to time, I use Perl regular expressions with backreferences to make otherwise impossibly tedious global replacements. Today, I discovered a quirk in their behavior, at least in the context of the UltraEdit Find and Replace engine.
My original find and replace expressions were as follows.
Find What:
Replace With:
The resulting replacement value is, obviously, not what I expected.
It seems that the presence of the backslashes in the text, most of which were part of the replacement literal, confused the Find and Replace engine. This is how I solved it.
Find What:
Replace With:
There are changes in both expressions.
In retrospect, I realized that doubling the backslashes in the replacement string should have been enough. Reverting to saved, I repeated the test, making only that change. As I anticipated, the amended replacement expression, as follows, also produced the desired result.
Takeaway: When your replacement expression contains both literal backslashes and backreferences to capture groups from a regular expression in the Find What box, you must double the literal backslashes, or they will be interpreted as invalid backreferences, and eaten.
UltraEdit rocks!
Find What:
"C:\\DOCUME~1\\DAG\\MYDOCU~1\\PROGRA~1\\VISUAL~1\\EXE\\Console\\WWLOGGER\\_notes\\(.*?)\.LOG"
..\Test_Data\\1.LOG
..Test_Data\1.LOG
Find What:
"C:\\DOCUME~1\\DAG\\MYDOCU~1\\PROGRA~1\\VISUAL~1\\EXE\\Console\\WWLOGGER\\_notes(\\.*?)\.LOG"
..\\Test_Data\1.LOG
- I moved the terminal backslash on the search path string, just to the left of the capturing group, inside the parentheses, making it part of the group.
- I doubled all of the backslashes in the replacement string.
..\Test_Data\WWLoggerRegularDrills.LOG
..\\Test_Data\\\1.LOG
UltraEdit rocks!
