Find in files to edit window without the file names
10
PostJul 28, 2005#1
I have a small problem that I cant figure out how to solve, hope somone can help me :?
I want to search in files and get the result to "edit window", so far so good. A new file opens and the result is listed perfectly. But, I don't want the file name to show in the start of every line!
Is there an option that I can choose so I only get listed what I actually searched for,and nothing else :?:
PostJul 28, 2005#2
No option! Here is my macro, which deletes everything except the lines where the text was found.
Find RegExp "%----------------------------------------^p"
Replace All ""
Find RegExp "%Find * :^p"
Replace All ""
Find RegExp "%Found * time(s).^p"
Replace All ""
Find RegExp "%*/[0-9]+: "
Replace All ""
Find RegExp "%Search complete, found*^p"
Replace All ""
UnixReOn
Remove the green lines, if you only want to remove the filename with the line number at start of each line.
206
PostJul 28, 2005#3
Try this macro on your search results. It leaves the line number. If not exactly as you want, at least it should give you some ideas.
UnixReOn
Find RegExp "^[A-Z][:].*[/](.*)$"
Replace All "\1"
10
PostJul 28, 2005#4
Thank you :D This is what I needed
