Suppose I would like to replace "A" with "B" in a section of text, not the whole document.
I do the following:
An obvious workaround is to keep the Replace window floating. Is there a trick to getting this to work when it is docked?
I do the following:
- Select the text.
- Press Ctrl+R to bring up the Replace window.
- Enter the Find and Replace values and select Selected text.
