Find text at the beginning of file
    Nov 07, 2019#1
    I have to search all files that start with a certain text. Some of the files have a BOM, others don't.
    Is there a way to do that with a regular expression?
    Regards
    Christian
    19176
      Nov 07, 2019#2
      Hi Christian,
      I hope that BOM is excluded from regex matching. This works for me (in Npp at least) - the beginning of the 1st line:
      (?<!(?s:.))^
      BR, Fleggy
        Nov 07, 2019#3
        My search text is object
        So the expression to use is (?<!(?object:.))^    ?
        And what kind is it? Perl, Unix, UltraEdit?
        I never really became familiar with regular expressions, so I have to ask.
        Christian
        19176
          Nov 07, 2019#4
          use Perl regex:
          (?<!(?s:.))^object
          or perhaps (you have to try):
          \A^object
          Please, check them carefully as I can't verify them in UE at this moment. The negative lookbehind (?<!...) sometimes does not work as supposed because of wrong implementation.
          BR, Fleggy
            Nov 07, 2019#5
            Thanks, this works.
            Christian
