IP List duplicate IP removal
12
    Jun 02, 2021#1
    I have a file with 1000s of IPs, is there a way I can strip out all the duplicate IPs to only 1 entry of it?
    Darcey
    Web Developer by day, DAW Tinkerer by night.
      Jun 02, 2021#2
      Run a sort with removing duplicate lines.
      12
        Jun 02, 2021#3
        Thanks for the info, will use that in future. However I just wrote a node script to do this for me and dump it to a json file.
        19476
          Jun 02, 2021#4
          Perl regexp, probably not very performing in a big file. Just for fun :)
          F: ^(.+)$\r\n(?=(?s:.*)^\1$)
          R: empty
          BTW I've just found a bug in UE regexp engine. You can try the regexp but it can skip some matches. I am going to report the bug to IDM.
          BR, Fleggy
