I have a file that I need to change about 1000 lines out of (that are unfortunately not all in sequence due to how the file is set up) where I need to paste a string of characters to a certain column on those line. Unfortunately each line (while starting with the same characters) is different, so I can't (that I know of) easily just do a Find->Replace. I can easily filter to just those lines and then hit the down arrow and CTL+V 1000+ times, but I'm hoping there's a much quicker/easier way to do it. But I'm not seeing a 'Paste only on visible lines' option, and if I just select the whole column in column mode and paste, it pastes to every line and not just the visible ones.
Is there a way to do what I'm wanting to, or do I just need to suck it up and do it manually? Thanks!
