Find blanks in XML
Find blanks in XML
    6:08 - Jul 22#1
    I have a structure, with a folder called tables and subfolders table 1, 2 etc.
    In each sbbfolder is placed a XML file called table[Folder].xml.
    there are a totol af + 600.000 lines.
    a few of them looks like:
    <c13>                    hej</c13>
    My problem is the blanks - '> ' , where the number of blanks can be whatever (less than 1000).
    So the example should be changed to:
    <c13>hej</c13>
     The blank problem can come in all lines, so i should look for >blank(s), not <c13>blank(s)
    The easy solution would take all xml files in the subfoldrs in one go, but as its a 'Few of' task, its ok with opening one xml file at a time.
    Best regards
    Edvard Korsbæk
    19476
      9:18 - Jul 22#2
      Hi Edvard,
      it is not clear how the element c13 (or similar which should be corrected) could look like. I suppose the simplest scenario - there are no nested elements and no EOLs inside the element body. Here is a Perl regexp which finds such lines and remove leading spaces from the body.
      Find: (?<TAG><(?<TAGNAME>\w+\d+)\b[^>]*+>) +(?<BODY>(?:(?!<|</).)++)(?=</\k<TAGNAME>>)
      Replace: $+{TAG}$+{BODY}
      This regexp searches elements with name from letters/underscores followed by some numbers. The sequence < or </ is not allowed inside the element body.
      Let me know if it does not work as you expect
      BR, Fleggy
