When you use find-in-files and do NOT specify that results go to edit window, the results come to a new window at the bottom of the editor frame. However, the tab stop value in this new window reverts to a value like 8 even though I have tab stop set to 2.
The result is not good -- lines are spread out so much that you rarely can see all of the line without horiz scrolling.
Is there a way to fix this or should it be sent in as a bug report?
