Find and replace if 2 matching search objects
    Nov 09, 2005#1
    Hello i see alot of tricky thing you can do with ultraedit
    But i have a problem....
    I need to delete a url some refer to another url,
    so what i dit have in my mind, is if i can sellect
    the start of the url (http://) and end on (&url=)
    so if i can make a replace search with the 2 keywords
    http:// if this line end on url= then delete the line from http to &url=
    Example
    http://microsoft.com&url=http://www.tucows.com
    The Bold tekst must be deleted and not the http://www.tucows.com
    still be untouched
    Example 2
    Before Cleaning
    http://dfgdfg.com&url=http://www.tucows.com
    http://micdfgdf.com&url=http://www.231231.com
    http://mifgfgf.com&url=http://www.dfgdfgdfg.com
    http://micfgfgf.com&url=http://www.tdfgdfgws.com
    http://micrfgfgfoft.com&url=http://www.tudfgdfgdfgs.com
    http://fgdddfgdfg.com&url=http://www.tdfgdfgdfgws.com
    After Cleaning looks like this
    I think you get the point... :D
    If you can help me out with my small problem, then you
    will save my as... for alot of "find line delete line and next,next,next"
    Hope there are a wize lady or man the can help me out with that
    And THX for read my prayers :cry:
    Best Regards
    Casper Rasmussen
    344
      Nov 09, 2005#2
      Hi Casper,
      Am I going right that you want to look for "http : //" and take the address there and this should be the new line content ?
      so take my macro. Use another loop if you do it for every line (no need to press play several times then ...)
      UnixReOn
      Find  "http://"
      Key RIGHT ARROW
      Key LEFT ARROW
      Find RegExp Select "($|[ ])"
      Cut
      DeleteToStartofLine
      DeleteToEndofLine
      Key DOWN ARROW
      Key HOME
      test it with this:
      dfgdfg.com&url=http://dict.leo.org
      micdfgdf.com&url=http://www.231231.com THIS STUFF HERE SHALL BE DELETED TOO ????
      mifgfgf.com&url=http://www1.dfgdfg.de
      micfgfgf.com&url=http:nothing to do cause no http and address here !!!
      fgdddfgdfg.com&url=http://last.one.here.it
      and the output is:
      dict.leo.org
      www1.dfgdfg.de
      last.one.here.it
      rds Bego :D
        Nov 09, 2005#3
        THX Alot Bego
        You Dit save my day THX Agen 8)
          Nov 09, 2005#4
          Ups i see it dit take the http:// away so if you can fix that 2 then i owe you one m8.
          My Mistage :oops:
          by the way i dit show you the example with out the http://
          I will show you precise what i dit want to tell you :lol:
          Example Before Cleaning
          http://www.tv.com/o.php?p=75&url=http://www.disney.com
          I need the Http:// now i will youst fix it with exel this time
          but if you can change the macro agen then, it will be more easy
          to next time....
          And Thx ALOT 4 YOU HELP M8 :wink:
          344
            Nov 09, 2005#5
            Hi gto get what you want. Sooo. I think I know:
            Try this:
            UnixReOn
            Find "url=http://"
            Key RIGHT ARROW
            Key LEFT ARROW
            Cut
            DeleteToStartofLine
            DeleteToEndofLine
            "http://"
            Key DOWN ARROW
            Key HOME
            I just extended the search to url=.... and the typed it again if found, so:
            http://www.lala.com/o.php?p=75&url=http://www.disney.com just another dumb stuff here to clean
            http://www.tv.com/o.php?p=75&url=http//www.errorMissingColon.com
            http://www.lala.com/o.php?p=75&url=http://www.this.one.works.too
            gets to
            Hope it helps.
            rds Bego
              Nov 09, 2005#6
              THX ALOT BRO
              :lol: :D :lol: :D 8) :o
