How to "find in file" and "copy to file"
    Nov 09, 2005#1
    I have a pb :
    I have to find in a file every line between 2 positions. In fact, the line juste after "PARSING IN CURSOR" and juste before "END OF STMT".
    I have 2 solutions :
    1/ I delete all the lines that is not between my 2 "expressions", include thes 2 lines.
    2/ I fetch the line between this 2 "expressions" and save it in a new file. This is the best solution, i guess !
    Exemple:
    Original:
    APPNAME mod='FXMEXPLR' mh=3136364418 act='' ah=4029777240
    PARSING IN CURSOR #29 len=64 dep=0 uid=10247 oct=3 lid=10247 tim=1105006329960485 hv=1880456616 ad='14c13620'
    SELECT SCE_VPD.SCE_CONTEXT('multicompany','company') FROM DUAL
    END OF STMT
    EXEC #29:c=0,e=86,p=0,cr=0,cu=0,mis=0,r=0,dep=0,og=2,tim=1105006329843848
    PARSING IN CURSOR #22 len=41 dep=1 uid=10249 oct=3 lid=10249 tim=1105006329978565 hv=1006647865 ad='12852700'
    SELECT SYS_CONTEXT(:B2,:B1) FROM SYS.DUAL
    END OF STMT
    EXEC #22:c=0,e=104,p=0,cr=0,cu=0,mis=0,r=0,dep=1,og=2,tim=1105006329978559
    FETCH #22:c=0,e=97,p=0,cr=3,cu=0,mis=0,r=1,dep=1,og=2,tim=1105006329978753
    FETCH #29:c=0,e=18284,p=0,cr=6,cu=0,mis=0,r=1,dep=0,og=2,tim=1105006329978869
    RPC CALL:SCE.PL_FUNC.GET_TOKEN;
    RPC EXEC:c=0,e=9060
    RPC EXEC:c=0,e=71
    What i Want to have:
    I'm not familiar with the macro, and what i done did not give a result.
    Can someone help me :)
    THKX,
    Greating from Marseille, France
      Nov 10, 2005#2
      This macro should do the job. I now have no time to write a explanation how it works, sorry!
      Bottom
      IfColNum 1
      Find MatchCase "PARSING IN CURSOR"
      IfNotFound
      Key HOME
      Key DOWN ARROW
      Find MatchCase Select "END OF STMT"
      Key HOME
      CopyAppend
      Key HOME
      Find "=====================^p"
      CopyAppend
      Key HOME
      NewFile
      NextWindow
      CopyFilePath
      CloseFile NoSave
      Open "^c"
      PreviousWindow
      Key UP ARROW
      Key END
      Find Up Select "\"
      Delete
      "\azerty.txt"
      SelectToTop
      Cut
      Key DEL
      SaveAs "^c"
      Edit: Improved macro code as requested!
        Nov 10, 2005#3
        Thankx a lot Mofi,
        It's work nice, but i would like to copy the clipboard in a new file named "azerty.txt",for exemple, instead of saving the result to the clipboard.
        Do you have any idea how to copy the clipboard to a new file (azerty.txt), and redirecting the the result adding the path to the file to be saved.
        Thkx ,
        Salem
          Nov 10, 2005#4
          Please check in the macro properties for this macro the option Continue if a Find with Replace not found. Now the macro will not simply stop when the search string is not found anymore and runs the macro code after EndLoop, which creates a new file and pastes the data collected in the clipboard. Then the macro ends and you can save the new file manually to whatever you want.
          I have also modified the macro code with additonal lines to automatically save the new file to what you suggested - see green lines above.
          Also the source file is closed without save and reopened to discard possible temporary modifications created by the macro (insert a line break at end of the file, if last line does not already have one). Delete the red lines, if you don't like this.
