Several replacements at once
    Dec 12, 2005#1
    When using "replace in files" option is it posible to make several replacements using "replace in files" option only once.
    Example:
    We want to replace:
    THIS1 with THIS11
    THIS2 with THIS22
    Is it posibble to make this replacement(like in example) using replace in files only once and not twice as a normal replacement of this example would require.
    Thank You
    206
      Dec 12, 2005#2
      Search String: THIS([0-9])
      Replace String: THIS\1\1
      This requires a Regular Expression search and replace with Unix-Style regular expressions active.
      It can be done just as easily with UE-style regular expressions - read the Help.
      It will replace THIS followed by any digit with THIS followed by two of the digits.
      You can use your imagination to expand on this quite a bit.
      Software For Metalworking
