Comma Delimited File Adding Double Quotes to fields
    Jan 20, 2006#1
    Product: Ultra Edit
    I'm looking to add double quotes to all fields in a comma delimited file that do not already have double quotes.
    i.e.
    Here is a sample record with 3 fields.
    "NAME",01245,"123 STREET"
    I want to change this to
    "NAME","01245","123 STREET"
    Any suggestions?
    Matt
    8
      Jan 20, 2006#2
      At worst, KISS and two steps.
      Replace . with "."
      Replace "" with "
      Just my luck. Finally found the end of the rainbow. Went there to get my pot of gold. Wrong end.
        Jan 20, 2006#3
        Thanks for the reply. I guess I was assuming that you knew "Text" fields can have commas in the middle of the field.
        i.e. "123 Fake St. Fakville,WA"
        I appreciate the feedback, but that will not work in my case. That is why I'd like to set-up a Regular Expression that will validate if the field has double quotes around it already. If the field does not, add double quotes. This is not an emergency, so don't go writing something that isn't already coded.
        Thanks again for your help,
        Matt
          Jan 20, 2006#4
          Use these 3 regular expression replaces in UltraEdit style.
          Find What: %^([~"^p]*^),
          Replace With: "^1",
          Find What: ,^([~"^p]*^),
          Replace With: ,"^1",
          Find What: ,^([~"^p]*^)^p
          Replace With: ,"^1"^p
            Jan 20, 2006#5
            Thanks for the Expression. There is obviously something that I'm not telling you because the last Find/Replace didn't find anything. I'm going to look at the help section for regular expressions and decode your awsome regular expression syntax. This is definately a new subject that I'm really interested in so no need to debug my problem. Thanks a million for the code.
            How's the weather over there?
            Regards from the east coast of the U.S.,
            Matt
              Jan 23, 2006#6
              I have detected, that my 3 replaces are not enough and you will get a bad file, if there are ',' inside a cell or a cell is empty (= ,, in the file).
              Here is a macro, which should do the job better. Don't forget to enable the macro property Continue if a Find with Replace not found.
              TrimTrailingSpaces
              Bottom
              IfColNum 1
              Find RegExp ""*""
              Find ","
              Replace All SelectText ";MOFI;"
              Find RegExp "%^([~"^p]*^),"
              Replace All ""^1","
              Find RegExp ",^([~",^p]*^),"
              Replace All ","^1","
              IfNotFound
              Find RegExp ",^([~",^p]*^)^p"
              Replace All ","^1"^p"
              Find MatchCase ";MOFI;"
              Replace All ","
              UnixReOn
              How this macro works:
              1) Make sure that last line of the file is terminated with a line break.
              2) Search in a loop for all "..." cells and replace all ',' inside such cells by ";MOFI;".
              3) Add "" to all cells of first column which do not already have it. "%^([~"^p]*^)," means find a string with 1 or more characters til ',' at start of the line and where the first character is not a " or a DOS line break (empty line).
              4) Add "" to all cells, which are not empty (,,) and do not already have "" in column 2 til last column-1.
              5) Add "" to all cells of last column (no , at the end, but a line break) which do not already have it.
              6) Convert the ";MOFI;" strings back to , as it should be.
              The macro is designed for working on a DOS terminated file. If you have a Unix file opened in Unix mode, you have to use ^n instead of ^p.
                Jan 24, 2006#7
                MOFI,
                I can't tell you how much I appreciate your help. Your instructions where perfect. Thank you, thank you, thank you.
                Thanks a Mil!
                Matt
