I don't know, if there is a solution with a single regular expression search. Maybe, it depends on the structure of your files. You have forgotten to give us some examples which is unfortunately typical for new forum users.
So I have quickly developed a macro which is able to do this independent of the file structure.
The first part searches for "John". You can modify the first
FindInFiles command to your needs (open files or specified files in a directory, regexp, ...), but it must write the result to a log file. This macro is taken from
Send all open file names to tool.
The second part is taken from
How do you run a Macro on open files?
It closes all open files except the search result file.
The third part I have developed new. It opens all files from the first search. So after the 3rd loop all files are opened which contain the word "John".
The last part is simply a Find In All Open Files for "Smith". You can modify all parameters of this
FindInFiles command, but it must run on all open files.
FindInFiles Log OpenFiles "" "" "John"
Find RegExp Up "%Search complete, found *^p"
Delete
NextWindow
Find "----------------------------------------^p"
Replace All ""
Find RegExp "%Find *^p"
Replace All ""
Find RegExp "%Found *^p"
Replace All ""
Find RegExp "/[0-9]+:*$"
Replace All ""
SortAsc IgnoreCase RemoveDup 1 -1 0 0 0 0 0 0
"ThisIsTheSearchResultWindow"
NextWindow
Find MatchCase "ThisIsTheSearchResultWindow"
Delete
CloseFile
IfEof
CloseFile NoSave
Key END
Cut
Key DEL
Open "^c"
NextWindow
FindInFiles OutputWin OpenFiles "" "" "Smith"
UnixReOn
Remove the last
red command, if you use regular expression in UltraEdit style by default instead of Unix style.
And don't forget to enable the macro property
Continue if a Find with Replace not found.
