Fixed Column Width File
    Feb 28, 2006#1
    I have a question for editing such a file in UEStudio.
    First: How can I with search and replace every for instance 60 Bytes do a Carriage Return so that the records are better readable.
    Second: Can I divide the columns then also with something like
    %(5.letter insert ;)
    Very much thanks in advance
    Nuker5
      Feb 28, 2006#2
      First use File - Special Functions - Insert String At Every Increment.
      To insert a line break use ^p as described in the dialog.
      For second switch to column mode and select all lines but no characters (thin blue line is displayed) and reformat the file like you want.
        Mar 01, 2006#3
        Very much thanks thanks.
        It did work how you said, very good.
        :P
        Greetings
        Nuker5
