How to replace patterns and preserve some variable portions?
8
    Mar 22, 2006#1
    Sorry I don't even know how to write the subject of my question. And thus don't know how to search possible existing solutions. But here is the case:
    I've many html files in a folder and they contain the pattern:
    <a href="../ch[V1]/[V2].html">
    where [V1] and [V2] varies among the files:
    <a href="../ch01/01-03.html">
    <a href="../ch12/8.html">
    I want to change them into the pattern:
    <a href="[V1]_[V2].html">
    Thus
    <a href="../ch01/01-03.html"> becomes
    <a href="01_01-03.html"> and <a href="../ch12/8.html"> becomes
    <a href="12_8.html"> .....
    Is there a way to make such changes by a single replace with UE32?
    Thanks a lot
    [email protected]
    30
      Mar 22, 2006#2
      Using perl regex (new in 12.00)
      Find:     "../ch([^/]+)/([^.]+)\.html"
      Replace:  "\1_\2.html"
      I am not familiar enough with UE style regex to comment on that method.
      6,626551
        Mar 22, 2006#3
        With Replace In Files with a regular expression. My first one is an UltraEdit style regular expression. First look at Configuration - Searching and make sure that Unix style Regular Expressions or Perl compatible Regular Expressions (UE v12) is not enabled.
        Then open Replace In Files, enable Regular Expressions and enter following:
        Find What: <a href="../ch^(*^)/^(*^).html">
        Replace With: <a href="^1_^2.html">
        See help of UltraEdit for details about regular expressions and an explanation how this works.
        Because it is easy, here is also the Unix style regular expression (not tested):
        Find What: <a href="\.\./ch(.*)/(.*)\.html">
        Replace With: <a href="\1_\2.html">
        8
          Sep 08, 2011#4
          Thank you very much roland and Mofi. That worked!
