Help in Firewall Log
    Mar 31, 2006#1
    I need to erase some lines that are are of the size standard... as make?
    Example:
    Mar 19 08:09:00 abab kernel: http: IN=eth0 OUT= MAC=00:02:55:23:21:d9:00:0a:41:7f:4b:40:08:00 SRC=87.196.128.37 DST=200.202.247.45 LEN=40 TOS=0x00 PREC=0x00 TTL=115 ID=8506 DF PROTO=TCP SPT=1295 DPT=80 WINDOW=65320 RES=0x00 ACK URGP=0
    Mar 19 08:09:00 abab kernel: http: IN=eth0 OUT= MAC=00:02:55:23:21:d9:00:0a:41:7f:4b:40:08:00 SRC=87.196.128.37 DST=200.202.247.4>http: IN=eth0 OUT= MAC=00:02:55:23:21:d9:00:0a:41:7f:4b:40:08:00 SRC=87.196.128.37 DST=200.202.247.45 LEN=52 TOS=0x00 PREC=0x00 TTL=115 ID=8585 DF PROTO=TCP SPT=1295 DPT=80 WINDOW=63908 RES=0x00 ACK URGP=0 <---Delete Very long
    Mar 19 08:09:00 abab kernel: http: IN=eth0 OUT= MAC=00:02:55:23:21:d9:00:0a:41:7f:4b:40:08:00 SRC=87.196.128.37 DST=200.202.247.45 LEN=40 TOS=0x00 PREC=0x00 TTL=115 ID=8401 DF PROTO=TCP SPT=1295 DPT=80 WINDOW=65320 RES=0x00 ACK URGP=0
    Mar 19 08:09:00 abab kernel: http: IN=eth0 OUT= MAC=00:02:55:23:21:d9:00:0a:41:7f:4b:40:08:00 SRC=87.196.128.37 DST=200.202.247.45 LEN=40 TOS=0x00 PREC=0x00 TTL=115 ID=8402 DF PROTO=TCP SPT=1295 DPT=80 WINDOW=63908 RES=0x00 ACK URGP=0
    Mar 19 08:09:00 abab kernel: http: IN=eth0 OUT= MAC=00:02:55:23:21:d9:00:0a:41:7f:4b:40:08:00 SRC=87.196.128.37 DST=200.202.2470 <---Delete Small
    Mar 19 08:09:04 abab kernel: http: IN=eth0 OUT= MAC=00:02:55:23:21:d9:00:0a:41:7f:4b:40:08:00 SRC=87.196.128.37 DST=200.202.247.45 LEN=40 TOS=0x00 PREC=0x00 TTL=115 ID=9176 DF PROTO=TCP SPT=1295 DPT=80 WINDOW=65320 RES=0x00 ACK URGP=0
    Mar 19 08:09:04 abab kernel: smtp: IN=eth0 OUT= MAC=00:02:55:23:21:d9:00:0a:41:7f:4b:40:08:00 SRC=65.123.82.253 DST=200.202.247.45 LEN=46 TOS=0x00 PREC=0x00 TTL=112 ID=42806 DF PROTO=TCP SPT=2673 DPT=25 WINDOW=17274 RES=0x00 ACK PSH URGP=0
    Mar 19 08:09:04 abab kernel: http: IN=eth0 OUT= MAC=00:02:55:23:21:d9:00:0a:41:7f:4b:40:08:00 SRC=87.196.128.37 DST=200.202.247.45 LEN=40 TOS=0x00 PREC=0x00 TTL=115 ID=9178 DF PROTO=TCP SPT=1295 DPT=80 WINDOW=65320 RES=0x00 ACK URGP=0
    Mar 19 08:09:09 abab kernel: smtp: IN=eth0 OUT= MAC=00:02:55:23:21:d9:00:0a:41:7f:4b:40:08:00 SRC=65.123.82.253 DST=200.202.247.45 LEN=40 TOS=0x00 PREC=0x00 TTL=112 ID=43602 DF PROTO=TCP SPT=2673 DPT=25 WINDOW=17124 RES=0x00 ACK FIN URGP=0
    I need this:
    The problem is the lines with lesser or bigger sizes that the standard!
    But the so great standard is changeable! 8O 8O
    The log have 500000 lines 8O
    thanks!
    344
      Mar 31, 2006#2
      Hi Max,
      until you cannot define how to "grab" the non-standard ´lines (identify the lines), no one can help you here...
      As I understood, the length of line is not possible to use as criteria.
      rds, Bego
        Apr 01, 2006#3
        This macro runs on line length 235 (valid http lines) and 240 (valid smtp lines). It deletes all lines which do no have a line length of 235 or 240 characters (without CRLF).
        Bottom
        IfColNum 1
        IfEof
        Key END
        IfColNum 235
        Key DOWN ARROW
        IfColNum 240
        Key DOWN ARROW
        SelectLine
        Delete
        If the standard changes, you also have to change the numbers at the 2 IfColNum.
        I have a second suggestion for your problem:
        Find all lines with correct count of spaces, list these lines (use option List Lines Containing String), copy the find result to clipboard and paste it into a new file or overwrite the existing file content with the clipboard content.
        The UltraEdit style regular expression search string to find all lines with the correct number of spaces (23) is:
        %[~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+[ ^t]++$
        But this regular expression will also not find the smtp lines with 24 (spaces) columns. To find all valid http and smtp lines use following regular expression in UltraEdit style:
        %[~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ ^{http^}^{smtp^}: [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+ [~ ^r^n]+[ ^t]++[~ ^r^n]++[ ^t]++$
        Well, invalid http lines with 24 spaces/columns will be also found by this search string. So it is not 100% perfect.
          Apr 04, 2006#4
          Thanks Bego and Mofi!!
