Removing underscores only from CSS class descriptors
5
    Apr 11, 2006#1
    Basically I want to remove any underscores that have been coded into CSS classes, so :
    .test_left
    Would become
    .testleft
    But would leave other underscore untouched, for instance href links with _blank targets and the like, so as long as the underscore is preceeded by a word and a period
      Apr 11, 2006#2
      find a period (followed by zero or more word characters) followed by an underscore (followed by 0 or more of any character matched pessimistically) followed by a word boundary
      replace with a period $1 $2
      you might have to repeatedly run this replacement as it only removes the first underscore in any identifier
      \.(\w*)_(.*?)\b
      .$1$2
      try that...
      5
        Apr 12, 2006#3
        Hey there, thanks for the tip, unfortunatley this doesn't even find a string. I tried with UNIX both on and off just to ensure that wasn't affecting anythihg, but didn't seem to work. If you have a solution using UltraEdit RegEx that would be superb! :)
        Thanks for the aisstance anyways!
        24
          Apr 13, 2006#4
          Hi
          Using the Perl regular expression engine you would do the following:
          Find what: .(\w+)_(\w+)
          Replace with
          .$1$2
          cheers
          5
            Apr 18, 2006#5
            Hey there,
            I must be doing something wrong because none of those solutions work unfortunately :(
            Thanks all for the help tho!
            Cheers
            29
              Apr 18, 2006#6
              You're probably not doing anything wrong. I think the reason those suggested solutions don't work is because "\w" matches underscores (it's equivalent to "[a-zA-Z0-9_]"). Also the period needs to be escaped because it normally means "any single character".
              Find:
              (\.[a-zA-Z][-a-zA-Z0-9]*)_([-a-zA-Z0-9]+)(\b|_)
              Replace:
              $1$2
              That should remove up to two underscores from class names. For classes with more than two underscores you'll have to run the search/replace again.
