Backreference problems using Perl regexes
kodavasal
    May 16, 2006#1
    Do backreferences work when using Perl regexes?
    In an HTML file, when trying to find matching tags and everything in between, the following regular expression
    <(\w+)>.*?</\1>
    gives an "invalid regular expression" error.
      May 17, 2006#2
      Only with the latest versions of UEStudio (v5.50) and UltraEdit (v12.10) released yesterday where exactly this issue was fixed according to the history in readme.txt. I have not tested, if it really works now with the latest versions.
      kodavasal
      kodavasal
        May 17, 2006#3
        I downloaded the update and it works! Thanks.
