Keep lines that end with a /
161
    Jun 22, 2006#1
    I have a huge list of lines and need to keep only the lines that have a trailing forwardslash /
    Also, what would be the code to remove all lines that contain a trailing forward slash?
    Example:
    abc/abc/abc/ ***has trailing forwardslash
    abc/abc/abc/filename.txt ***does not have trailing forwardslash
      Jun 22, 2006#2
      See Delete all lines not starting with a special phrase how to do it manually or use the first macro from this forum thread and replace the line
      Find MatchCase RegExp "%Starting phrase*^p"
      by
      Find RegExp "%*/^p"
      Or use the macro at How to delete all lines not containing specific word or string or expression? with UnixReOff and replace the line
      Find "[images]"
      by
      Find RegExp "/$"
      161
        Jun 22, 2006#3
        That works for a starting phrase, but I need something that will look at the last character and then if it is != to a forwardslash, then delete the line.
        For the example file:
        abc/abc/abc/
        The code you posted does not flag either line as one that contains a forwardslash. I tried placing a "/" inside the find, but that didn't work.
          Jun 23, 2006#4
          Hmmm.. I just tried again to search for %*/^p and it picked up every line. Not sure why this didn't work before.
          I basically did a find that line, and replace it with some odd text combination, and then did a find the off text combo, and replace it with blank to delete it. Looks like it worked :)
