I often use the search in files feature of UE. When I "browse" through my directories on my hdd with the windows explorer, and I want to find some strings in some files, I must open UE, click on the search in files feature, and then select the directory to search in.
But I have the directory open already in the windows explorer, so what I want to know is, is there a possibility to right-click in the windows explorer and do a search in files in the selected directory? Perhaps this is possible with some command line parameters of UE?
Thanks a lot for your help
