Replace each number with number+5
    Aug 19, 2006#1
    hello!
    I'm try to find a way to replace some numbers in .xml files!
    Example: <Location top="5563" left="1192" bottom="5685" right="1244"/>
    replace to: <Location top="5563" left="1192" bottom="5690" right="1249"/>
    how to do it? thanks!
      Aug 19, 2006#2
      You need 2 macros for this job. The first one which you must create first is my universal submacro CountUp which is posted at counter ?
      After you have created the submacro CountUp, create the main macro for your individual usage which needs the macro property Continue if a Find with Replace not found enabled.
      The code for the main macro is:
      Clipboard 7
      Find RegExp "bottom="[0-9]+""
      IfNotFound
      Key LEFT ARROW
      Key LEFT ARROW
      Key LEFT ARROW
      Key LEFT ARROW
      Key LEFT ARROW
      PlayMacro 1 "CountUp"
      SelectWord
      SelectWord
      SelectWord
      SelectWord
      Find RegExp "right="[0-9]+""
      IfNotFound
      Key LEFT ARROW
      SelectWord
      SelectWord
      SelectWord
      SelectWord
      SelectWord
      Edited macro on 2006-08-20:
      Replaced
      Key LEFT ARROW
      Key LEFT ARROW
      Key LEFT ARROW
      Key LEFT ARROW
      with the single command SelectWord because the macro should work for all numbers not only for numbers with 4 digits.
        Aug 20, 2006#3
        thanks a lot! I try it now...
