deleting csv columns
    Jan 25, 2007#1
    I've read some other column posts and met my basic needs. But I'd like to know if I can do it faster.
    I want to:
    1. open a csv file
    2. delete the first 3 columns
    3. keep column 4
    4. delete the columns after column 4
    I've accomplished this by converting to fixed width columns, then doing two deletes. Do I have to convert to fixed width? Can't I delete variable length columns?
      Jan 25, 2007#2
      The following Unix style regular expression does the job:
      replace:
      with:
      \1
      or - even better - if you prefer the Perl-regexp-style:
      replace:
      with:
      $1
      ^ means: Start of line (might be omitted here)
      ? means: non-greedy, just up to the NEXT Komma.
      () means: my first variable = $1
      .* means: all characters
      next, columns, stays,BECAUSEITS4, IM, gonna, be, deleted, too
      BECAUSEITS4
      rds Bego
        Aug 01, 2008#3
        I found a smarter, more readable(?) approach. Here is it in a macro, you can "extract" the find/rep from there:
        The macro is called "delCol7":
        PerlReOn
        Find RegExp "^(([^;]*;){6})[^;]*;"
        Replace All "$1"
