Search/Replace Duplicate Lines - Regular Expression Help
    Jun 11, 2007#1
    Hello all,
    I have delved into the UltraEdit help files and this forum trying to find a solution to my problem. I have a log that documents the x, y, and z coordinates of an event. The event is run 12 consecutive times. 11 entries in the log contain pre-planned (theoretical/ideal) coordinates and a 12th entry contains the actual coordinates where all 12 events occurred. I need to replace (delete) the 11 theoretical event entries. I saw in a similar thread Removing lines with partial duplicate content with spaces.
    a solution for doing this but I don't understand how to employ the regular expressions (I'm not a programmer) in my application. I am using UEStudio version 6.20A+2. Below is a sample of an event log I am working on:
    Line               Point       X Value     Y Value       Z Value     JD&Time
    S1132.0            5132.01V1     0.0   0 0 0.01705678.4  703551.5 537.7134073317
    S1132.0            5132.01V1     0.0   0 0 0.01705678.4  703551.5 537.7134073329
    S1132.0            5132.01V1     0.0   0 0 0.01705678.4  703551.5 537.7134073342
    S1132.0            5132.01V1     0.0   0 0 0.01705678.4  703551.5 537.7134073354
    S1132.0            5132.01V1     0.0   0 0 0.01705678.4  703551.5 537.7134073406
    S1132.0            5132.01V1     0.0   0 0 0.01705678.4  703551.5 537.7134073419
    S1132.0            5132.01V1     0.0   0 0 0.01705678.4  703551.5 537.7134073431
    S1132.0            5132.01V1     0.0   0 0 0.01705678.4  703551.5 537.7134073444
    S1132.0            5132.01V1     0.0   0 0 0.01705678.4  703551.5 537.7134073456
    S1132.0            5132.01V1     0.0   0 0 0.01705678.4  703551.5 537.7134073508
    S1132.0            5132.01V1     0.0   0 0 0.01705678.4  703551.5 537.7134073521
    S1132.0            5132.01V1     0.0   0 0 0.01705683.9  703551.9 537.7134073533
    S1420.0            5137.01V1     0.0   0 0 0.01719908.8  710179.6 470.6134073821
    S1420.0            5137.01V1     0.0   0 0 0.01719899.0  710181.7 470.6134073605
    S1420.0            5137.01V1     0.0   0 0 0.01719899.0  710181.7 470.6134073618
    S1420.0            5137.01V1     0.0   0 0 0.01719899.0  710181.7 470.6134073630
    S1420.0            5137.01V1     0.0   0 0 0.01719899.0  710181.7 470.6134073643
    S1420.0            5137.01V1     0.0   0 0 0.01719899.0  710181.7 470.6134073655
    S1420.0            5137.01V1     0.0   0 0 0.01719899.0  710181.7 470.6134073707
    S1420.0            5137.01V1     0.0   0 0 0.01719899.0  710181.7 470.6134073720
    S1420.0            5137.01V1     0.0   0 0 0.01719899.0  710181.7 470.6134073732
    S1420.0            5137.01V1     0.0   0 0 0.01719899.0  710181.7 470.6134073744
    S1420.0            5137.01V1     0.0   0 0 0.01719899.0  710181.7 470.6134073757
    S1420.0            5137.01V1     0.0   0 0 0.01719899.0  710181.7 470.6134073809
    From the example above you can see the line, point, x, y, and z values are the same for 11 of the 12 recorded events and the 12th contains the actual positioning. The Julian Date and time stamp increments and is not identical.
    Can someone please help me with the regular expressions to search and replace these duplicate entries.
    Best regards,
    William
    236
      Jun 11, 2007#2
      can you try if this Perl regex works for you? (If you haven't done so yet, activate Perl regular expressions in the options dialog first)
      Search string:
      (?:(?:^((?:[^\s]+ +){5})).*?\r\n){11}(\1.*?)$
      Replace string
      \2
      It assumes that there is the same number of spaces at each location in a 12-line block. If that's not the case, I'd run a replace multiple spaces by one space first, regex for that would be
       {2,}
      (note the leading space), replace with " ".
      One caveat: If you don't always have 12 consecutive lines that belong together, the regex might mismatch. If that may be the case, the regex will need to be changed.
      Best regards,
      Tim
        Jun 11, 2007#3
        Tim,
        thanks for the input. The Perl regular expression as posted worked.
        Best regards,
        William
