delete everything after the last semicolon on a line
61
Advanced UserAdvanced User
61
    Jul 28, 2008#1
    I have lines like this
    this is a test;delete all of this
    test line two; this I want ; delete all of this
    regular epxressions;are;great; when; you;know;how;to;use;them;delete this stuff
    I want to delete after the last semicolon on each line.
    I am using UE 14.10.1.0.1024
    119
    119
      Jul 28, 2008#2
      Using Perl-style regular expressions:
      Find What: [^;]*$
      Replace With: ^p
      61
      61
        Jul 28, 2008#3
        This results in the following
        this is a test;test line two; this I want ;regular epxressions;are;great; when; you;know;how;to;use;them;
        Not what I was hoping for as a result. I want each line to just lop off the trailing stuff after the last semicolon.
        looking more for this kind of result
        this is a test;
          Jul 29, 2008#4
          Fantastic!!!!!
          Could you please explain the expression so I understand how it works.
          Thanks a million
            Jul 29, 2008#5
            I suggest a Perl regular expression search string [^;\r\n]+$ and an empty replace string. That would not change the current line ending format.
            There is a help page about Perl regular expression in help of UltraEdit, but here is a short explanation.
            Square brackets [...] means find any character specified inside the brackets.
            If the first character after [ is ^ then the meaning is reversed. So [^...] means find any character except those specified inside the brackets.
            \r is the character code for the character carriage return.
            \n is the character code for the character line-feed.
            So [^;\r\n] means find 1 character which is not a semicolon, not a carriage return and not a line-feed.
            The + after the bracket means find the previous expression 1 or more times (* means 0 or more times). Because the previous expression means any character except semicolon, CR and LF, this regular expression selects now all strings not containing these 3 characters. But we want to find only those strings on end of line.
            So the last regex character $, which means end of line without selecting the line ending characters, anchors the search to the end of the line.
            236
              Jul 29, 2008#6
              Very good improvement, Mofi.
              I would suggest yet another modification:
              Search for
              (?<=;)[^;\r\n]+$
              and replace with nothing. The positive lookbehind expression (?<=;) makes sure that there is in fact a semicolon after which to delete the rest of the line. Otherwise, lines that don't contain a semicolon will be deleted entirely (save the CRLF).
              If that's what is requested - but sklad2 wrote it that way :)
              61
              61
                Jul 30, 2008#7
                It is working great!!!!
                (?<=;)[^;\r\n]+$
                This is the one I am currently running.
                I am thinking about getting Regex buddy. I hope this will help my regex skills :mrgreen:
                Thanks for all of the great help with regular expression!!!!!!!! :D
