function list group definition for css
11
    Oct 20, 2010#1
    I would like to separate the functions, id's & classes in the function list
    Does anyone have a group definition for css?
    6,685587
      Oct 20, 2010#2
      You know that you can mix style definitions for elements, classes and id's on the same line like following definition demonstrates?
      h2, p.red, #attention { color:red }
      However, I took the regular expressions of Cascading Style Sheets (CSS) 1.0-2.1 (case-sensitive) and without much thinking about the expression splitted them up into 3 groups using following definitions:
      /TGBegin "Elements"
      /TGFindStr = "%[ ^t]++^(["*+,^-0-9:=>@^[^]_a-z|~][ ^t^p"*+,^-0-9:=>@^[^]_a-z|~]+^){"
      /TGFindStr = "%[ ^t]++^(["*+,^-0-9:=>@^[^]_a-z|~][ ^t^p"*+,^-0-9:=>@^[^]_a-z|~]+^)/^*[~/{}]++^*/[ ^t^p]++{"
      /TGEnd
      /TGBegin "Classes"
      /TGFindStr = "%[ ^t]++^([a-z]++.[ ^t^p"*+,^-.0-9:=>@^[^]_a-z|~]+^){"
      /TGEnd
      /TGBegin "Identifiers"
      /TGFindStr = "%[ ^t]++^(#[ ^t^p"*+,^-0-9:=>@^[^]_a-z|~]+^){"
      /TGEnd
      This is definitely not perfect, but maybe enough for your requirements.
      Please note that I needed to add %[ ^t]++ on every expression because otherwise it is impossible with the UltraEdit regular expression engine not supporting lookbehind to avoid a class definition like
      .s5 { font-size:18pt }
      to be listed in group Elements (finds only s5) and group Classes (finds .s5). So the expressions now find only style definitions in CSS files or style blocks.
      Further note that a CSS definition like
      table.black td { border-style:solid; border-width:1px; border-color:#000000 }
      is listed in group Classes and not in Elements. I can't really decide on interpreting a CSS definition for a nested element as class definition or as element definition. I prefer classifying a definition for an element inside another element with special style as class definition.
      11
        Oct 20, 2010#3
        Thanks Mofi that was what I needed, I'm not too good with regular expressions yet.
        Is there any way to make the groups collapse?
        6,685587
          Oct 20, 2010#4
          Collapse with the code folding engine? No, that is not possible. You can write a macro or script to collapse all CSS definitions on execute for the 3 groups of elements, elements of a definite class and for elements with identifiers. But that requires or better makes sense only when the CSS definitions in your files are always stored in these 3 blocks which is in general not the case from what I have seen in many, many CSS files. Folding a CSS definition spanning over multiple lines is already defined and possible.
          Please note: It is possible with the posted expressions above that some CSS definitions are not listed at all in the function list view. The first example I posted above is such a CSS definition not present in the function list view.
