function list doesn't work with private or public keyword?
    Jun 22, 2005#1
    starting to use OOP in PHP 5, I found that my PHP method:
    private function name()
    will not appear in the function list. I edited the wordfile.txt and managed to get at least two options in front of the function keyword working, but the third will not work.
    Works:
    /Function String 2 = "%[^t ]++^{public^}^{protected^}[^t ]+function[^t ]+^([a-z0-9_&]+^)"
    This works for public and protected, but I don't have a clue how to add a third element "private" can work and how I could implement the optional element "abstract". Looks I don't know enough about the UltraEdit RegEx.
    Thanx for any suggestions.
    Burkhart
      Re: function list doesn't work with private/public keyword
      Jun 05, 2006#2
      Next time list more function examples. I have to get the necessary information about "abstract" via an internet search engine because I have no knowledge about PHP5.
      Following 3 additional function strings should now add all your functions to the function list:
      /Function String 3 = "%[^t ]++^{private^}^{abstract[^t ]+private^}[^t ]+function[^t ]+^([a-z0-9_&]+^)"
      /Function String 4 = "%[^t ]++abstract[^t ]+^{public^}^{protected^}[^t ]+function[^t ]+^([a-z0-9_&]+^)"
      Also possibe is:
      /Function String 2 = "%[^t ]++^{public^}^{abstract[^t ]+public^}[^t ]+function[^t ]+^([a-z0-9_&]+^)"
      /Function String 4 = "%[^t ]++^{protected^}^{abstract[^t ]+protected^}[^t ]+function[^t ]+^([a-z0-9_&]+^)"
