C++ Class scoped function member (indented function definition) in Function List
481
    Nov 05, 2014#1
    Before I go meddling with the C/C++ Group parsing rules I thought I'd ask if anyone else has already updated it to support class member functions (in the header file)? Out the box it only supports globally scoped functions and class member functions that are defined in the .cpp file e.g.
    // FILE : B.h
    class B
    public:
    	void Test(){} // not in Function List
    namespace blah
    	void test2(){} // not in Function List
    void test3(){} // In Function List
    #endif
    // File B.cpp
    void B::op1() // In Function List
    The indents are 1 tab.
    Thanks - Brad
    6,685587
      Nov 07, 2014#2
      Change in %APPDATA%\IDMComp\UltraEdit\wordfiles\c_cplusplus.uew
      /TGBegin "Functions"
      /TGFindStr = "^(?!if\b|else\b|while\b|[\s*])(?:[\w*~_&]+?\s+){1,6}([\w:*~_&]+\s*)\([^);]*\)[^{;]*?(?:^[^\r\n{]*;?[\s]+){0,10}\{"
      to
      /TGFindStr = "^[\t ]*(?!if\b|else\b|while\b|[\s*])(?:[\w*~_&]+?\s+){1,6}([\w:*~_&]+\s*)\([^);]*\)[^{;]*?(?:^[^\r\n{]*;?[\s]+){0,10}\{"
      to allow optionally tabs or spaces at beginning of a function definition line.
      481
        Nov 07, 2014#3
        Thanks Mofi. That did the trick.
