/L12"T-SQL" T-SQL_LANG Line Comment = -- Block Comment On = /* Block Comment Off = */ File Extensions = SQL
/Delimiters = ~!@%^&*()-+=|\/{}[]:;"'<> , .?
/Function String = "%[ ^t]++[ps][a-z]+ [a-z0-9]+ ^(*(*)^)*{$"
/C1
ABSOLUTE ACTION ADA ADD ALL ALLOCATE ALTER AND ANY ARE AS ASC ASSERTION AT AUTHORIZATION AVG
BACKUP BEGIN BETWEEN BIT BIT_LENGTH BOTH BREAK BROWSE BULK BY
CASCADE CASCADED CASE CAST CATALOG CHAR CHARACTERCHARACTER_LENGTH CHAR_LENGTH CHECK CHECKPOINT CLOSE CLUSTERED COALESCE COLLATE COLLATION COLUMN COMMIT COMMITTED COMPUTE CONFIRM CONNECT CONNECTION CONSTRAINT CONSTRAINTS CONTAINS CONTAINSTABLE CONTINUE CONTROLROW CONVERT CORRESPONDING COUNT CREATE CROSS CURRENT CURRENT_DATE CURRENT_TIME CURRENT_TIMESTAMP CURRENT_USER CURSOR
DATABASE DATE DAY DBCC DEALLOCATE DEALLOCATE DEC DECIMAL DECLARE DEFAULT DEFERRABLE DEFERRED DELETE DENY DESC DESCRIBE DESCRIPTOR DIAGNOSTICS DISCONNECT DISK DISTINCT DISTRIBUTED DOMAIN DOUBLE DROP DUMMY DUMP
ELSE END END-EXEC ERRLVL ERROREXIT ESCAPE EXCEPT EXCEPTION EXEC EXECUTE EXISTS EXIT EXTERNAL EXTRACT
FALSE FETCH FILE FILLFACTOR FIRST FLOAT FLOPPY FOR FOREIGN FORTRAN FOUND FREETEXT FREETEXTTABLE FROM FULL
GET GLOBAL GO GOTO GRANT GROUP
HAVING HOLDLOCK HOUR
IDENTITY IDENTITYCOL IDENTITY_INSERT IF IMMEDIATE IN INCLUDE INDEX INDICATOR INITIALLY INNER INPUT INSENSITIVE INSERT INT INTEGER INTERSECT INTERVAL INTO IS ISOLATION
JOIN
KEY KILL
LANGUAGE LAST LEADING LEFT LEVEL LIKE LINENO LOAD LOCAL LOWER
MATCH MAX MIN MINUTE MIRROREXIT MODULE MONTH
NAMES NATIONAL NATURAL NCHAR NEXT NO NOCHECK NONCLUSTERED NONE NOT NULL NULLIF NUMERIC
OCTET_LENGTH
OF OFF OFFSETS ON ONCE ONLY OPEN OPENDATASOURCE OPENQUERY OPENROWSET OPTION OR ORDER OUTER OUTPUT OVER OVERLAPS
PAD PARTIAL PASCAL PERCENT PERM PERMANENT PIPE PLAN POSITION PRECISION PREPARE PRESERVE PRIMARY PRINT PRIOR PRIVILEGES PROC PROCEDURE PROCESSEXIT PUBLIC
RAISERROR READ READTEXT REAL RECONFIGURE REFERENCES RELATIVE REPEATABLE REPLICATION RESTORE RESTRICT RETURN REVOKE RIGHT ROLLBACK ROWCOUNT ROWGUIDCOL ROWS RULE
SAVE SCHEMA SCROLL SECOND SECTION SELECT SERIALIZABLE SESSION SESSION_USER SET SETUSER SHUTDOWN SIZE SMALLINT SOME SOME SPACE SQL SQLCA SQLCODE SQLERROR SQLSTATE SQLWARNING STATISTICS SUBSTRING SUM SYSTEM_USER
TABLE TAPE TEMP TEMPORARY TEXTSIZE THEN TIME TIMESTAMP TIMEZONE_HOUR TIMEZONE_MINUTE TO TOP TRAILING TRAN TRANSACTION TRANSLATE TRANSLATION TRIGGER TRIM TRUE TRUNCATE TSEQUAL
UNCOMMITTED UNION UNIQUE UNKNOWN UPDATE UPDATETEXT UPPER USAGE USE USER USING
VALUE VALUES VARCHAR VARYING VIEW
WAITFOR WHEN WHENEVER WHERE WHILE WITH WORK WRITE WRITETEXT
YEAR
ZONE
/C1
JOIN
KEY KILL
OCTET_LENGTH
YEAR
ZONE
