Open Brace with nested "if" doesn't work
    Jul 28, 2005#1
    I'm testing software with Ratonal Robot (SQA = basic dialect). In my wordfile I have
    open brace strings ... "If" "Select Case" For"
    close brace strings.... "End If" "End Select" "Next"
    This works fine, as long I do not have nested statements like:
          If   bla Then
               If blu Then
                  do something
               Else If
                  do something
               End If
          Else If
               If blu Then
                  do something
               Else If
                  do something
               End If
          End If
    The matching "End If" for the first If is not found. Is there any posibility to get that to work?
      Jul 17, 2006#2
      The problem here is that the word "If" is also a word in "End If" and in "Else If". UltraEdit cannot know that the "If" in "End If" and "Else If" should be ignored. The only solution I have found is following:
      /Open Brace Strings = "Then" "Select Case" For"
      /Close Brace Strings = "End If" "End Select" "Next"
      Well, not really good, but better than nothing. It's always bad if a language is based on identifier terms and not on identifier words.
