Having more identifiers for comment colours
    Aug 04, 2005#1
    Hi folks!
    I wonder if anyone knows it is possible to create more identifiers for comment colours.
    For example: I currently have identifiers for "/*", "*/" and "#if(0)", "#endif".
    Is it possible to add more, such as "#if(ABC)", "#endif /*ABC*/
    Thanks in advance.
      May 27, 2006#2
      No. More than 2 block comments cannot be defined. Maybe the code folding feature or the hide selected text feature would be helpful.
      For example following macro code will hide all "#if(ABC)", "#endif /*ABC*/" blocks. Enable the macro property Continue if a Find with Replace not found for this macro.
      ToggleBookmark
      Find "#if(ABC)"
      Key HOME
      Find Select "#endif /*ABC*/"
      IfSel
      HideOrShowLines
      Key DOWN ARROW
      GotoBookMark
      ToggleBookmark
      If you use code folding, you have to specify the /Open Fold Strings = and /Close Fold Strings = in your wordfile for your language.
