How do I highlight words with $?
    Aug 10, 2005#1
    Variables in PHP are represented by a dollar sign ($). How do I get the full word to be highlighted?
    Presently I could just only get the dollar sign to be highlighted. The word remains black.
    E.g.
    $var=1;
    $result == 'true';
    Thanks in advance.
    119
    119
      Aug 10, 2005#2
      This is described in the Keywords beginning with a Sub String section of the help for syntax highlighting. Add a color group for variables and use ** to colorize all words beginning with a $. e.g.
      /C5"Variables"
      You'll also need to ensure that $ is not listed as a delimiter.
        Sep 20, 2005#3
        Is there a way to highlight only the first 'n' number of characters using the '**' syntax? For example, I might have data=test or data=prog1 and I only want the 'data=' to be highlighted.
        6,683583
          Sep 20, 2005#4
          Add = to the delimiter characters /Delimiters = and the = additionally to the color group with the substring definition. Then only "data" will be highlighted by the substring specification and = will have the same color. Highlighting only n characters of a substring is not possible.
