Differents colors for xml tags
    Aug 12, 2005#1
    I'd like to use differents colors for differents groups of tags. But there is a little problem:
    /C1"Group1"
    <tag1-1> </tag1-1> <tag1-2> </tag1-2>
    /C2"Group2"
    <tag2-1> </tag2-1> <tag2-2> </tag2-2>
    this part works. But when i've <tag2-3 attribute="value"/>, i'd like the closing part (/>) to be the same color as the opening one. But if I define:
    /C1"Group1"
    <tag1-1> </tag1-1> <tag1-2> </tag1-2> <tag1-3
    /C2"Group2"
    <tag2-1> </tag2-1> <tag2-2> </tag2-2> <tag2-3
    the /> is not highlighted and if I add
    // /> in one group, it won't match the other group color.
    Is there a way ?
    Thx
      Aug 13, 2005#2
      No solution for your problem!
      UE does not "understand" the displayed language, is not specialized on a specific language and it is not possible to define a word in more than one group.
        Aug 16, 2005#3
        thought so.
        Thx anyway
