Languages specified by filename?
    Sep 22, 2005#1
    I have an often-used XML file. I want to specialise the function list just for this file so I can pick out specific element names.
    I thought I might be able to create a new language (derived from XML) and give a filename rather than extension but this doesn't seem to work.
    Anybody know if this can be done.
    macon
    10
      Sep 22, 2005#2
      Using File Names = instead of File Extensions = at the end of the /L line works fine for me - with the file name(s) only, without path! Maybe that's the reason?
        Sep 22, 2005#3
        Thanks Andreas,
        I had tried that initally but it didn't seem to work. It turns out the order of the languages is important. After I moved the "File Names = catalog.xml" language above the "File Extensions = XML" language it started working.
        Matt
