Smart Indenting
Smart Indenting
    Sep 25, 2005#1
    When I first got Ultra-Edit, I opened a javascript file up.
    When I reindented it I was dissapointed:
    Notice that if you indent something like this:
    if (1)
    }else{
    you get:
    if (1)
    }else{
    So you'd have to use:
    if (1)
    else{
    or:
    if (1)
    else
    if you wanted it to indent correctly.
    The last two styles of coding suck ass. }else{ is the bestest way to do it.
    Goto wordlist.txt.
    Find the language you want to indent correctly.
    Replace the indent & unindent with:
    /Indent Strings EOL = "{"
    /Unindent Strings SOL = "}"
    80
    Advanced UserAdvanced User
    80
      Sep 28, 2005#2
      I actually prefer the last method. To each his own. However, those aren't the only problems with SmartIndent. For C and some other languages you don't need to use braces if there is only one line following the if. UE doesn't seem to handle this case at all.
      if ( something )
          something_else = nothing;
      else
          something_else = another_thing;
