Ignoring a delimiter character when used in specific keyword
8
    Oct 12, 2005#1
    #1) I use brackets "[" and "]" as delimiters for S+ syntax highlighting, but there are instances when I would like to highlight certain keywords which include brackets (such as "[1]"). Is this possible?
    #2) Can regular expressions be used to define keywords in a wordfile, or can they only be used to define function strings?
    Thanks!
    6,683583
      Oct 12, 2005#2
      #1) No, not possible.
      #2) Regular expressions in UltraEdit style can only be used for the function strings, not for keywords or anything else.
      8
        Re: Ignoring a delimiter character when used in specific key
        Oct 16, 2005#3
        Thanks Mofi!
