Delimiter and double click selection
11
    Jan 24, 2006#1
    I have a string like:
    Dim $Variable1 = "Some Value"
    in the wordfile, $ is specified as a delimiter, but when I double click $Variable1, only Variable1 is selected. This actually happens with or without the delimiter in the wordfile.
    Anyone know what to do to enable the full word selection?
    344
      Jan 24, 2006#2
      Hi Steve,
      look at the help file for "Double Click Selections". Here the German version:
      Wird gleichzeitig mit dem Doppelklick der primären Maustaste die Steuerungstaste (Strg) gedrückt gehalten, wird eine Zeichenkette und nicht nur ein einzelnes Wort ausgewählt. Dies kann zur Auswahl eines Dateinamens, einer E-Mail-Adresse usw. hilfreich sein.
      And here the English version:
      If at the time the primary mouse button is double clicked the control key is pressed, a string is selected rather than just a single word. This can be very useful in selecting filenames, e-mail addresses, etc. The characters that delimit the string are configurable under the Delimiters topic under the Editor branch under Configuration in the Advanced menu. This function works on a single line only.
      So, also press ctrl key while double clicking and you're done. :D
      rds bego
      11
        Jan 24, 2006#3
        Thank you. I wonder why this is seperate to the operation of the delimiters in the wordfile. It would seem to me that they should be the same.
