Any way to 'prefold' code folds?
    Apr 09, 2006#1
    I'm working with a 'very large file' format (Poser) and have designed a Syntax Highlighting for the format. These files can be 100's MB and it would be nice to be able to prefold sections (esp. certain subsections) that can be folded.
    Does UE have anything like this? Since the file format is something like this:
    	keywordA
    		keywordB
    where the entire file is always encapulated by '{' and '}', "Collapse All" just collapses the entire file (how useful is that - not). What would be nice is either a level collapse or some sort of way to use keyword to determine what to collapse. If this could be done using Macros, then I'm all for it. :)
    Robert
      Apr 09, 2006#2
      If you activate the option Save bookmarks at Configuration - Editor - Bookmarks then UltraEdit will save the current code folding for every file in it's uedit32.ini. So you only have to fold your file once manually and next time you open it UltraEdit will automatically fold it again.
      You can also create a macro which selects a specific block and folds it. For your example the macro is:
      Find RegExp "% keywordB"
      Find RegExp Select "% }"
      HideOrShowLines
      Find RegExp "% keywordA"
      HideOrShowLines
        Apr 09, 2006#3
        Thanks, Mofi. I'll give it a try and see how far I can take it.
        Robert
