The ^{A^}^{B^} - matches expression A or B
I can only get it to work in a Function string with literal A or B.
Can the expression be used inside the ^( ^) tag?
Secondly, can the expression be a generalised expression or only a literal?
A worked example would be really helpful.
TIA
Paolo
TIA
Paolo
