collapsing multiple-line strings
    May 01, 2006#1
    hi
    I use ultraedit for my php-scripting an was wondering, if there is the possibility to collapse long strings that strech to multiple lines.
    example:
    $txt[inst_step0] = '...much stuff ...
    ...*even more stuff* ...
    ...*about 50 lines later* ';
    now it is quite annoying to have all this stuff there and not being able to collapse it. so is there a solution for my problem?
    greez
    wombat
      May 01, 2006#2
      Sorry, but I think folding strings is not possible with the /Open and /Close Fold Strings = settings. You can only select the multi-line string and use View - Hide/Show Lines - Hide/Show Selection to manually fold it.
