highlighting of some custom tags within HTML
    May 31, 2006#1
    i wanted to introduce some additional tags within the HTML which is a variant of the HTML comment tag "<!-- ... -->". my custome tag would look sth like this "<!--[selector ...]-->".
    i tried appending this to the default wordfile.txt under the HTML section:
    /C3"TSL Selectors" STYLE_EXTENSION
    <!--[/comment]-->
    <!--[comment
    it just doest work even tho i took off the "Block Comment On". pls help and thanks in anticipation.
    6,683583
      May 31, 2006#2
      This is not working because <>[/ are also delimiter characters with a special handling of <> if HTML_LANG is present in the language definition line. So "<!--[/comment]-->" and "<!--[comment" are terms and not words. The syntax highlighting engine only highlights words and not terms.
      A possible solution could be
      /Marker Characters = "[]"
