c/c++ comments parsed incorrectly
    Jun 05, 2006#1
    I inherited some C++ code where each routine is preceeded by a block comment in the following style:
    main
    int param
    printf("Hello world.");
    UltraEdit highlights all of the code following the block as a comment. Apparently UltraEdit does not parse the "*/" followed by "//" followed by "*" correctly. If I break it up like this, "*/ //*", or this, "*/// *", or even this, "*////*", it highlights OK. But this, "*///*", does not work.
    I'm using UE V10.10c.
    Is there any way for me to edit my wordfile so that UltraEdit parses this correctly?
      Jun 06, 2006#2
      Yes, v10.10c of UE does not highlight this code example correct. This is not a wordfile problem. This is a problem of the syntax highlighting engine of UltraEdit. With the same wordfile v11.20a and v12.10+3 of UE highlights it correct. You have to upgrade to a newer version of UE or you reformat your comments.
